SR20 vs VG30 flywheel
I can’t find this information on google for some reason. Does anyone know for sure if the bolt pattern to the crank is the same between SR and VG flywheels?
Also does anyone know if the ring gear diameter is the same between the SR and N/A VG. I know the TT is larger.
In other words could you put a VG flywheel/clutch onto an SR and vice versa?
Thanks.
Anyone? Someone on this site has an SR and VG flywheel sitting around. Or if you only have one could you take a minute to measure the outside diameter of the ring gear please?
Help this man do something awesome with cars!
I’m pretty sure that it is I got a brand new sr20 clutchmasters stage three with light flywheel if yu interested
I may be interested. PM me a price.
Pm’d
Found the answer. SR20 is slightly smaller diameter but bolt pattern is the same.
