Im selling my redtop sr swap cause i just dont have the time to build anything right now, the engine is in extremely good shape on the inside and out, I do not know exact kms but I’m guessing it is around 13x,xxx, great way to save on an sr swap here with just needing to get a couple other things
SR20DET Motor set: comes with the motor,tranny, stock intake mani, exhaust mani and stock MINT T25, hacked up wiring harness and all the rest except you will need ecu, starter, and power steering pump (if you want it) valve cover is sanded down
Text or call 905-925-8598
