Stoptech 332x32 BBK for Audi A4, needs work, $700/BO
I finally put stock calipers with new pads and rotors on my car. This came off a B5 A4 quattro, not sure if it will fit a B6 but I’m pretty sure they have the same calipers/brackets.Aside from needing new pads, the calipers on this kit could use some work. They had started to develop a creaking sound which was the calipers hanging up a bit. The car would pull to the left under hard braking because the right side was worse. It would also cause the ABS to sometimes kick on when it wasn’t necessary and for the light to come on because one side was doing more work than the other. Since the inner pad on the passenger side wasn’t making full contact, a small part of the rotor became rusted from not touching the pad under braking. The rotors should be turned because of this. Finally, since I had to use a little heat on the brakes lines, the rubber peice at the end melted a little. None of the clear rubber that covers the Stainless Steel line itself melted and this will in no way affect the kit other than cosmetically.
This kit goes for $2200 on ebay. It has black ST-40 calipers and slotted rotors, they are not drilled however. Comes with SS lines too. The rotors are about 13", a 17" wheel will clear, you may need spacers though.
The brackets are still on the calipers and I will include 4 extra bracket bolts. The kit simply re-uses the stock ones but I have 4 extra for anyone just in case.
The calipers need some work, it needs new pads, and the rotors need to be turned so I am asking $700/BO. Feel free to call or text, Jeremy @ 716-380-5426.
http://i733.photobucket.com/albums/ww331/JeremyTabak/035.jpg
This is the melted rubber at the end of one of the lines
http://i733.photobucket.com/albums/ww331/JeremyTabak/036.jpg
Driver side caliper/pads
http://i733.photobucket.com/albums/ww331/JeremyTabak/034.jpg
Driver side rotor outer
http://i733.photobucket.com/albums/ww331/JeremyTabak/033.jpg
Driver side rotor inner
http://i733.photobucket.com/albums/ww331/JeremyTabak/031.jpg
Passenger side caliper/pads, you can see the outside pad is much more worn than the inside one
http://i733.photobucket.com/albums/ww331/JeremyTabak/027.jpg
Passenger side rotor outer
http://i733.photobucket.com/albums/ww331/JeremyTabak/030.jpg
Passenger side rotor inner
http://i733.photobucket.com/albums/ww331/JeremyTabak/029.jpg
Can I get this moved to the parts section? My bad.
moved to network just because those are kinda BA.
bump
How about $600?
I could do $500 for these
curious… maybe itll help you sell… but
whats the part numbers??
and what are the piston diameters?
Free bump here for a great seller!
Brembo actually copied ST design here with their F50/F40 calipers. Many guys like the ST’s better because they are two piece forged deign over the Brembo one piece cast design, hence why the ST creak sometimes. Anyways someone should buy these! They have brackets for tons of cars such as VW’s, BMW’s, Corvettes, etc etc.
Jer if you need these gone let me know I’ll try to bolt them up to the GMC.
They are ST-40’s as stated in the add.
http://www.raceshopper.com/stoptech_big_brake_kits.shtml
PN# is
ST83.102.4600
Still cant find the piston diameter details… but each calipers weighs:
3.6kg
Bump, I forgot to look up the piston diameter. I’ll get around to that.
