Asking Price: $600 Condition: Used Location: Toronto Will Ship?: Y Description:
I got them for my project but I am going to a different route,so, I selling them for $600.
Calipers are in really good shape and it also comes with SS lines and ENDLESS CC-R pads with 95% life left on them and complete hardware.This is a bit about the pads if u guys don’t know them:http://www.jdm-option.com/eng/parts/05_09/endless.html (the pads are going for ± $300)
ps:ps: I’ve tested fit the calipers on my skyline gts and they are bolt on,yes bolt on,they are straight bolt on w/o custom brackets to make them work.
that is correct, though you wont have an ebrake. to fix this problem you can use the Z32 ebrake system with the Z32 rear rotor. it was only smaller by like mm’s soo it will work. plus if you go this route you wont need the 3mm spacers, as what i read up on.
WELL, if they ARE the same as an R33 gtr system, you will need the ROTOR as well, as they are thicker then the stock disks. Or risk the piston poppin out as the pad gets thin.
This is what I got from another forum talking about sti calipers:
Rear sti calipers will need z32 rear drum assemblies with z32 rotors,
Brembo’s size:
Sentra SE-R Spec -V 04-06 uses a 300mm x 22mm Rotor
300zx (z32) 91-96 uses a 280mm x 30 rotor
350z/g35 Brembo (z33) uses 324 x 30mm rotor
STI brembo 326mm x 30mm rotor
EVO rotor 320mm x 32mm rotor
r33GTR has 324 and 300 mm discs F/R (http://www.skylinesaustralia.com/forums/R33-Gtr-Rear-Brakes-R33-t136174.html&hl=r33+brembo+calipers+size)
