Hi Guys, I am picking up pair of brembo rotors (front + rear) but I need bigger calipers and break pads? since my future plan is to turbo charge the car. any suggestions of what I can get and where?
Do a search here and google for 300zx or z32 brake upgrade.
i was looking to buy bigger calipers as well. either from 300zx, R32 or S14. There’s just one thing i’m wondering tho. Since the calipers are not engineered the same way as the single pot s13 ones, where do they bolt on? Directly on the s13 4 bolt hub where the clamp bolts on? Or on the caliper clamp? Or you need custom work?
s14 and s13 calipers are the same as far as I know.
z32 and R32/33/34 fronts are also interchangable. I believe Q45 fronts bolt up as well without any problems.
The only custom work you need is redrilling the rotors to 4 lug.
Hope this helps,
Pavel
