Alright so my front speakers are blown, and I can’t seem to get the speaker cover off lol. Do i need to take off the whole door panel, from what I can see the cover is screwed on… wondering if anybody has done this before so i dont break anything.
oh ya i took the whole things apart,so what u got to do is take the panel of then the speaker cover should come off,i did it long time ago just trying to remember how i did it i think the cover was screwed on to the door on the inside
ya it is screwed in through the back. Guess I’ll just have to play around with it. What are the speaker dimensions for a 93 240sx?
hey, yea the s13 are easy but hard at the same time. its just clips holding it on and a couple screws. The hardest to take off in the power window switch. ive broken just about all of myne. if you can get that off with no problem, then you unplug he wire and away you go.
i know the switch has a metal clip at the front that needs to be pushed . if not you will crack the plastic
4 by 6 all around
So are both the door panels and rear hatch speakers all 4"x6" size? I’m looking to replace all 4.
quite simply…yes
