It takes way more than JUST a bigger turbo and more boost to make power in a diesel. Diesels are totally different that gas motors. A gas motor its mostly air that makes your horsepower (to a certain extent) … a diesel … its the fuel that makes the power. Your can take a diesel with its stock fuel setup … put on a HUGE SP61 turbo … or even go with a big twin setup … and your not going to put down big numbers what so ever. You HAVE to have the fuel to push everything. They need to be overfueled to make big horsepower and tq. Once you reach a certain power level … the fuel will over take the turbo with make your run extreamly hot. Right now im lacking a some air and im already pushing 43 psi. I can peg my 1600 pyro and aluminum melts at around 1250.
Not trying to be a dick here … just thought id put in my imput
Im aware that anytime you increase airflow, fuel needs to be incresed to compensate. Im not suggesting that Ford needs to push the tsunami to the “unsafe” temperature levels that your diesel is reaching under full load. But your truck is also making over 900 ft/lbs of torque. Ford is only looking to make 500-600 ft/lbs. I was simply stating it would have been easier to make 600 ft/lbs with a diesel than it would have been with gasoline.
I totally understand that you were just stating that it would be WAY easier to make 600 ft/lbs with a diesel powerplant. Just didn’t want other people to get confused … thats all … :bigthumb:
Okay, let me rationalize what im trying to say here for you. If you were going to build a fast truck… Would you choose an F350 Crew Cab as your platform? Or would you pick a 2 door F150?
Yea, i see what your saying. But the V10 doesnt come in the F150’s, so maybe thats why, or maybe b/c they did the lightning and the supercharged harley trucks and both werent hot sellers. Who knows why for wants to do this to a F350, i guess they only know.
