i ordered my plug wires and recieved them today they are the taylor sport compact series, made for the 90 s13. now my question is i open the box and there is 6 wires in there now the last time i checked i only have a 4cyl. so i am wondering whats up. because i checked the product number. and called the performance shop where i got them and they are the rigth ones. so i am thinking that the 5th and 6th wires are for the wire that comes off the cap. maby they are made for the dohc and the sohc… any sugestions on this problem… or are they just the wrong wires…
thanks guys
BRent
- 1-4 plug wires
- wire from igntion coil to cap
- extra ground?
all these aftermarket kits come with two coil---->distributor wires. They are 2 different lenghts. Choose the one that fits your setup the best, ussually the shorter one.
Then you have your 4 wires for distributor to plugs. You will know if they are 91+ wires…trust me. They have a long connector end for the plugs since the DE plugs sit in the middle of the head.
Andrew.
Andrew is right, the Taylor set comes with an extra ignition coil wire.
ok got it i put them on this morning they fit pritty good to not to long… i used the shorter coil wire… thanks alot guys
thats what this boards for
Brent
