TH400 Speedometer gear
I need a speedometer gear to drive the gauge sender for my TH400. Any stock one will work, as I can adjust my speedometer for whatever gear I am running.
Which gear do you need the one on the output shaft or the gear that goes into to housing that drives the speedo cable?I work at wholesale transmission and we have alot of used ones in stock.
I’m pretty sure I need the one that drives the speedo cable, but I’m not sure if the one on the output shaft is even on there. When the trans was built for me it came with a freeze plug where the gear goes lol. I will have to take the tail off and look…
just pm me what you need and i can get them.Chances are that the one on the output shaft is missing also,so you would need the output shaft gear,the clip to hold it on the shaft,the housing for the driven gear and a driven gear.
pm sent.
Edit: LOL, it just occurred to me that you are 3 buildings away from where I work. I am at Anastasi Trucking, I’ll swing by sometime during the week.
That will be fine.
