We have been developing this kit for a few months now and we are very pleased to finally announce the release today!
The first kit is installed on an Evo X sitting on our dyno right now. If the weather decides to get above 0 degrees, we might get some results in soon!
But minus the charts and graphs and numbers, just the quality and design is truly enough to take notice!
(Click HERE for the High-Res Photo)
STM > EVO X > TURBOS & BOOST > BOLT-ON TURBO KITS > STM TOP-MOUNT V-BAND TURBO KIT
- Evolution X 4B11 CZ4A
The all new STM Top-Mount V-Band Turbo Kit for the Evo X is a complete bolt-on masterpiece! Nothing but the highest quality, workmanship, parts and fabrication for your car! The STM manifold is tig welded in-house, then ceramic-coated to keep temps down. The hand-made stainless V-band downpipe is proudly stamped with the STM badge. The STM lightweight aluminum intercooler piping is polished to a mirror shine! This is the must-have kit for 2015!
SAFETY FIRST!
DO NOT INSTALL THIS KIT IF YOU HAVE A PLASTIC VALVE COVER!
You must run an aluminum valve cover. The heat may be too great for the plastic valve covers and it is not worth the risk! If you don’t have an aluminum valve cover, we offer the OEM Mitsubishi for $335.
This kit is designed to work with the stock blow off valve recirculation tube.
If you have any custom spec requests, feel free to give us a call and we can work with you!
Everything pictured above is included. Click the link for a high-resolution photo.
- Choice of Ball Bearing FP Turbo
- Ceramic Coated Manifold
- Stainless Downpipe & Atmosphere Dump
- Aluminum Upper Intercooler Pipes
- Intake Pipe
- Intake Heatshield & Hardware
- DEI Titanium Turbo Blanket
- DEI Titanium Heat Wrap & Fasteners
- DEI Cool Tape
- TiAL MVR 38mm Wastegate (Your choice of color)
- STM Silicone Couplers (4)
- T-Bolt Clamps (6)
- OEM Mitsubishi Exhaust manifold Gasket
- Remflex Exhaust Gasket & Bolts
- V-Band Clamps for Turbo & Downpipe
- Coolant Lines & Hose Clamps
- 10AN Oil Lines & Fittings
- Turbo Fittings
- 3mm Vacuum Hose
Forced Performance Turbo Options:
Ball-Bearing with TiAL .82 AR Housing.
- FP 6466TZ
- FP 3794HTZ
- FP 3786HTZ
- FP 3586HTZ
- FP 3582HTA
- FP 3076HTA
Please Note!
Not just ours, but ANY aftermarket turbo kit for the Evo X is well known to generate a ton of heat! We include a lot of DEI heat wrap, and provide to you the best quality parts in the industry, but it is your job to ensure a safe and successful install! More heat wrap is available in the link below and we suggest using it!! Please be safe and monitor your engine bay regularly.
More heat protection is available here: STM > DIY & FABRICATION > HEAT WRAP
We have a couple Evo X’s in the shop getting this kit installed and we will update as we go!
Stay Tuned!!
