Does the SR20 use the same throttle cable as the KA24?
the DOHC ka cable works fine
bracket (that sits on the intake mani) needs to be modded to fit properly
Yeah I asked that question backwards. I meant if the KA cable will work for the SR20. Which I see it does.
Thanks
I used the cable from my KA-E (SOHC) actually and never had any issues.
was it long enough?
i thought the kae one was short and so had to be lead overtop the valve cover
it works fine just not as pretty i guess
i had a single cam ka and sr20ed my car and yes the cable runs across the valve cover. never had a problem tho
As you can see it only ran over the corner on the pass side…not that big of a deal IMO.
it complements your razo sticker nicely
That razo sticker was there to cover rust…
