Tial F46 gate, 780cc injectors and Kaaz LSD for S chassis.
Tial F46: I bought this a few years ago, used it for about 500 miles then switched to a different mani that used a different gate, worked great and includes flanges that I cut off the old mani. $200
http://i149.photobucket.com/albums/s74/Iceman1151/gate3.jpg
http://i149.photobucket.com/albums/s74/Iceman1151/gate1.jpg
http://i149.photobucket.com/albums/s74/Iceman1151/gate2.jpg
780cc injectors(6): These are rochester/delphi low impedance with a 16mm lower oring and 11mm top and roughly 65mm from center to center of orings. I had this on a custom fuel rail setup but I believe these fit on some kind of honda or dsm. Numbers printed on them read 9293 17113742. Doesn’t include rail or lower bungs. $125
http://i149.photobucket.com/albums/s74/Iceman1151/Rail1.jpg
Kaaz 2way LSD: I bought this used 4 years ago with about 1500 miles on it, only put 1000 more on since then and its just been sitting. Comes in a s13 housing but the output shafts have slightly larger bolt holes since I ran DSS axles.(You can either swap in yours or get larger bolts for your axles) Also includes a never opened can off KAAZ lsd fluid(diff housing still has fluid in it as well). I don’t have a pic but we all know what a diff housing looks like. Quit skipping your tires around corners with the welded and buy this for baller status. $450
would u take 400 for the diff?
400 cash I’d take
Interested in the injectors.
Did you buy them brand new? How many miles? Did you even use them? Why are you selling? Do you have any type of paperwork with them?
No; last owner had 1500 on them I put a additional 1000; for 1000 miles; switched to e85 needed larger injectors; No, that is why I’m selling for cheap.
