ok, i seriously need help with this. I have looked every where and I can’t find out what timing belt to use with my ca18det and I don’t want to just rush out and buy a ca18de on until I know what works since I had all of those issues with the powersteering.
ok i dont know this for sure but wouldnt both belts be the same?i mean it is the same engine right,only ones not turbo and one is,which correct me if im wrong but the turbo system has nothing to do with the timing belt.the only difference i could see is if one was SOHC but since they both DOHC i dont think it would be a problem.
the ca18de one will work! i have the ca18det tech manual also if u need it
The ca18de will work fine because im using one.
