I have an sr20det and i just swapped out my stock 370cc fuel injectors for new 550cc injectors. Now when i drive, i feel the boost, but at top end around 4-5000 rpm it loses all boost and wants to quit on me…anyone know why…
if its overfueling what should i do?
you are most likely running right as hell.
Get a fuel management system in order to back off on the fuel. Your ECU still think you have the 370cc installed and pumping about 27% of additinal fuel at any given RPM . More under boost.
u need wider rims, that is ur problem.
did u do any research before this or putn bigger injectors in with no managment at all, seemed like a great idea
my injectors were bad and was was non-functional so i got the 550’s from someone…
what would be the best fuel management system to run on the sr set-up?
u cant just drop in those injectors and go , im in the same boat i have a set of 555 sitting on my desk but the ecu has to be redone i looking into the nistune option! 400 from australia then someone to tune it so still well under a grand! the other thing is upping yourmaf sensor , more fuel + more air. dont
waste money on the safc II
