Would like to know to what level my valve cover should be torqued to, in the process of putting back on and would like to put it on properly. Thanks for whoever can help me out.
If you have that rubber gasket on there, not tight whatsoever. Just a tad more than finger tight. There isn’t a whole heck of a lot of pressure under the valve cover.
what arron said but if u want exact tourque there is FSM’s all over the net they will tell u torque specs for anything u need
Wasnt it 6 ft lbs? Its been a while since I had mine off…
i stuck a 10mm on a 1/4 inch extention and that is all i did. figer tight that and your golden.
NO RACHET, just an extention.
yea i do have the rubber seal so i wont tighten it too much, thanks, i will try about 6lbs and see how hard it is. good advise
Whats the part number for a SR20DET valve cover gasket?
I have tryed looking it up and haven’t been able to find it. Obviously I am looking in all the wrong places, so please help me out!
Valve cover is 13270-52F00
Spark plug tube seals is 13270-53J13
Thanks alot!!
Where is a good site with all the parts numbers?
Only one I know of is www.sr20det.nismo.org and it is decent, but doesn’t have everything.
Go and download nissan Fast here
http://www.n-e-c-c.com/forum/viewtopic.php?t=1087&highlight=nissan+fast
Half way down second page
The page you give on that thread has dead links.
Anywhere else I can get ahold of a JDM FAST?
I am downloading the euro one, but it probably isn’t as good.
