QUESTIONS? CALL US NOW!
TOLL FREE NUMBER:
1-877-JDM-0-JDM
1-877-536-0-536
Here are some Toyota engines that we offering for New Yorkers.
~All the engines we have are in good mint working order.
~Compression test has been done.
~All the motor we sell has strong to perfect compressions.
~Each motor is hand picked in Japan and taken out of running cars.
~We can do the compression test and take pictures of it for potential customers upon request.
SPECIAL SHIPPING OFFER:
~ $200 FLAT SHIPPING FOR ANY ENGINES COMBO TO ANY BUSINESS ADDRESS ONLY IN NEW YORK ONLY
~ $250 FLAT SHIPPING FOR ANY ENGINES COMBO TO ANY RESIDENTIAL ADDRESS IN NEW YORK ONLY
~ANYWHERE OUTSIDE OF NEW YORK PLEASE CONTACT ME FOR CORRECT PRICING
~SOME ENGINES WE OFFER FREE SHIPPING, PLEASE READ DETAILS
~ALL PRICES ARE IN USD
~IF ANYONE DECIDE TO DRIVE DOWN TO PICK UP THE ENGINES FOR A BETTER PRICE PM ME
JDM Startlet GT 91-94 4E-FTE TURBO ENGINE W/ 5 SPEED LSD TRANSMISSION $1200+Shipping
INTAKE MANIFOLD
TURBO MANIFOLD
THROTTLE BODY
SPARK PLUGS + WIRES
DISTRIBUTOR
INTERCOOLER
STARTER
AC COMPRESSOR
POWER STEERING PUMP
DIP STICK
VALVE COVER
INCOMPLETE WIRE HARNESS
ECU
JDM 91+ TOYOTA SOARER 1JZ 2.5 L TWIN TURBO ENGINE $1750 Shipped
Engine block Top and Bottom
RWD Automatic Transmission with ECU
INTAKE MANIFOLD
TURBO MANIFOLD
TWIN TURBOS
FUEL RAIL
THROTTLE BODY
SPARK PLUGS
ALTERNATOR
STARTER
AC COMPRESSOR
POWER STEERING
INJECTORS
OIL PAN
VALVE COVER
IGNITER
UN-CUT WIRE HARNESSES
ECU
ACCESSORIES (STOCK SENSORS)
JDM TOYOTA SUPRA 1JZ 2.5 L TWIN TURBO ENGINE & 5 Speed Transmission $2050 + shipping
RWD 5 Speed Transmission
CLUTCH AND FLYWHEEL
PRESSURE PLATE
INTAKE MANIFOLD
EXHAUST MANIFOLD
TURBOS
FUEL RAIL
THROTTLE BODY
SPARKPLUGS
ALTERNATOR
STARTER
AC COMPRESSOR
POWER STEERING
INJECCTORS
SPARKPLUGS
OIL PAN
VALVE COVER
MASS AIRFLOW SENSOR
IGNITER
WIRE HARNESSES
ECU
ACCESSORIES (Stock SENSORS)
JDM 98+ TOYOTA CHASER VVT-I 1JZ 2.5 L TWIN TURBO ENGINE + 5 SPEED TRANSMISSION $2999.99 Shipped
RWD 5 Speed transmission
INTAKE MANIFOLD
TURBO MANIFOLD
TURBOS
FUEL RAIL
THROTTLE BODY
SPARKPLUGS
ALTERNATOR
STARTER
AC COMPRESSOR
POWER STEERING
INJECTORS
OIL PAN
VALVE COVER
IGNITER
UN-CUT WIRE HARNESS TO ECU
ECU
JDM 98+ TOYOTA CHASER VVT-I 1JZ 2.5 L TWIN TURBO ENGINE + AUTOMATIC TRANSMISISON $2250 shipped
INTAKE MANIFOLD
TURBO MANIFOLD
TWIN TURBOS
FUEL RAIL
THROTTLE BODY
SPARKPLUGS
ALTERNATOR
STARTER
AC COMPRESSOR
POWER STEERING
INJECTORS
OIL PAN
VALVE COVER
IGNITER
ECU
JDM 2JZ TWIN TURBO ENGINE WITH AUTOMATIC TRANSMISSION $1899.99 + SHIPPING
ENGINE BLOCK TOP AND BOTTOM
FLYWHEEL
INTAKE MANIFOLD
EXHAUST MANIFOLD
TWIN TURBOS
FUEL RAIL
THROTTLE BODY
SPARK PLUGS
ALTERNATOR
STARTER
AC COMPRESSOR
POWER STEERING
INJECTORS
OIL PAN
VALVE COVER
MASS AIRFLOW SENSOR
IGNITER
ECU
94+ JDM CELICA GT-4 3S-GTE TURBO ENGINE 5 SPEED AWD TRANSMISSION $2150 SHIPPED
AWD 5 SPEED TRANSMISSION
CLUTCH AND FLYWHEEL
PRESSURE PLATE
INTAKE MANIFOLD
EXHAUST MANIFOLD
TURBO
WATER COOLED INTERCOOLER
FUEL RAIL
THROTTLE BODY
SPARK PLUGS
ALTERNATOR
STARTER
AC COMPRESSOR
POWER STEERING
INJECTORS
SPARKPLUGS
OIL PAN
VALVE COVER
CUT WIRE HARNESSES
JDM 3S-GTE CELICA 1998+ ENGINE + AWD 5 SPEED TRANSMISSION $2150 SHIPPED
CLUTCH AND FLYWHEEL
PRESSURE PLATE
INTAKE MANIFOLD
EXHAUST MANIFOLD
TURBO
INTERCOOLER
FUEL RAIL
THROTTLE BODY
SPARK PLUGS
ALTERNATOR
STARTER
AC COMPRESSOR
POWER STEERING
INJECTORS
SPARK PLUGS
OIL PAN
VALVE COVER
WIRE HARNESS TO ECU
ECU
JDM Toyota Levin AE111 4AGE 20 Valve 1.6L engine with 6 speed lsd transmission $1799.99 shipped
6 SPEED LSD TRANSMISSION
CLUTCH AND FLYWHEEL
PRESSURE PLATE
INTAKE MANIFOLD
EXHAUST MANIFOLD
FUEL RAIL
THROTTLE BODY
DISTRIBUTOR
ALTERNATOR
STARTER
AC COMPRESSOR
POWER STEERING
INJECTORS
SPARK PLUGS
OIL PAN
VALVE COVER
WIRE HARNESSES
ECU
More engines to come!
PM ME IF YOU GOT ANY QUESTIONS
