Need a Trans jack to rent or borrow for this weekend, i will pick up and return
Any help would be appreciated
This is not the one for a floor jack but a regular size one that a shop would use
I have one, but it needs fluid and a handle. I also dont have any of the brackets for it. So it probably wouldnt be much use. Hell I havent used it in over 6yrs. Not even sure if it would raise up or not once fluid was added.
Thanks… but i need an actual functioning unit used for it’s inetended use
