I was going use it for a project car but I have other things to work on right now. So just trying to see how much i can get for it. The car definitely need a paint job. There’s only a little bit of surface rust on it, underneather the car is completely rust free.
This civic used to be an automatic and was converted into a manual. When I had the engine out, I did a vtec swap for the engine and change all of the gaskets on the engine including the timing belt and water pump. The tranny is perfect without and grind with new clutch and flywheel. The best part about the car is no rust. The car needs a paint job but I was waiting for spring to paint it. The shell has about 122k and I took the dx cluster out and put in a ex cluster with 64k. The car is inspected and is good till November of 2006.
97 honda civic dx
Mini me d16y8 swap with 70k on the motor
99 front end conversion
Front tsunami lip and side skirt
type r rear lip
Si fog lights
Projector headlights
99 tail lights.
2001 honda prelude seats
Intake
Header
Apexi customer 2.5” dunk exhaust
New clutch and flywheel
New gaskets on the engine
Timing belt and water pump
Short shifter
higest offer so far is 3k. if anyone can beat that because the buyer won’t have money til another two weeks can have the car.
