ok, well this is absolutely everything you need to get started with dj’ing. hell, these tables are even a great upgrade. only reason i’m selling them, well, one, the money would be nice, and 2, i just never really could get back into it. the tables are brand new, i’ve only put MAYBE 10 hours on them. the crossfader works fine on the mixer. and i’ve never had any problems with it. it will come in the original box with all cables that came with it. i’m not too inclined to sell it, just doing some cleaning before i move to ottawa, and stuff that i have room in a house for, i wont have room in an apartment for.(thank god a friend will take all my 240 parts to hold on to lol) i’d love to keep them, but they wont do me much good if i don’t have the room to set them up. i’ll throw in a few gigs of music if someone wants that also.
$770 OBO shipped
the specs on the turntables are:
Frequency Response: 30 Hz to 20 kHz +1/- 2 dB/ RIAA filter
THD+N (Line): < 0.03% at 1 kHz
Signal to Noise Ratio (Ref to Max. Level): <-65 dB
Digital Output (SPDIF): 0.5Vp-p (Load 75 ohms)
Type: 3-speed full manual
Motor: 8 pole, 3 phase, brushless DC motor
Driving Method: Direct Drive
Speeds: 33 1/3, 45 rpm and 78 rpm
Wow and Flutter: Less than 0.15% WRMS (JIS WTD) with 33 1/3 rpm
Pitch Controls: +/- 8%, +/- 12%
Starting Torque: More than 1.6 kgf.cm
Starting Time: Less than 1 sec with 33 1/3 rpm
Braking Time: Less than 1 sec with 33 1/3 rpm
Braking System: Electronic Brake
Time for Speed Change: Less than 1 sec with 33 1/3 rpm, Less than 1 sec from 45 to 33 1/3 rpm, Less than 1 sec from 33 1/3 to 78 rpm
Audio Output: Phone/Line output
Tone Arm Type: Static balanced straight shaped tone arm with cardan’s suspension
Effective Arm Length: 191mm
Tracking Force Range : 0-3g
Applicable Cartridge Weight: 6-10g
the specs for the mixer are
2-channel mixer
High-quality crossfader delivers long life and superior performance
2-way crossfader curve control for mixing or scratching; optical technology extends fader life in cut mode
3-band EQ per channel with +9/-26dB boost/cut
Microphone input with separate gain and 2-band EQ
Cue Pan and Cue Volume controls
Fader Start outputs for use with compatible CD players
the final scratch system works a lot like Serato Scratch Live. it lets you play MP3’s from your computer on your turntables. you can scratch, backspin, mix, do everything with it that you can with a normal record. one thing i have noticed though, is that if you get enough dust on the needles, it will interfere with the signal from the vinyl, so you have to keep them clean.
