If you have any of the parts listed below and you’re looking to make room in your garage let me know. Parts don’t have to be exact…just do the job.
LSA Conversion- PARTS LIST
Supercharger with bypass - 12622236 19257754
ZL1 Supercharger lid / CTSV ??? -ZL1 -12622236
intake manifold bolts (10) - 11588718 AC Delco 217-3350
EVAP solenoid - 12639188
Intake
Manifold Gaskets - 19180613
3 Bar Map Sensor- 12592525
IAT extension
harness
IAT Sensor- 12614717
cooler insulator - 12612467
Dayco Gold Poly Rib 5080650 8 Rib 65" Belt - 5080650
100 mm idler Pulley (Metro)
2.55 MM pulley (Metro)
Serpentine Belt main assembly
Supercharger Isolator Lingerfelter - L960130709
ZL1 Engine beauty cover - 12639443
Engine beauty cover studs (4) 12639443
ZL1 fuel pump
Fuel Rail - 12605222
LSA/LS9 Fuel Injectors 12598646
280158187 (56lbs)
Supercharger intercooler radiator (Factory ZL1)- 22879421
***Silicon Intake.com liquid to air intercooler radiator-- wat001002
Intercooler Filler neck Cap - 25884797
25884797/226697069 Intercooler
Filler Neck Off a Colbalt
*LSA Bosch CTSV intercooler pump - 20945282
(Lingenfelter CTS-V Varimax Intercooler Pump Upgrade Kit 2009-13)
*ZL1 Front Hose kit - 22962566 (NOT NEEDED FOR G8 INSTALL)
Crank Pulley (aka balancer) - 12603916
SLP Crank Pinning Kit - GM LSx Motors
Crank pulley bolt - 11570046
Water pump gasket - 12630223
Timing Cover Gasket - 12633904
Timing Chain GXP - 12633904
Crankshaft seal - 12585673
ZR1 Camshaft - 12638427
Camshaft sprocket 3 bolt - 12586481
3 camshaft sprocket bolts - 12556127
oil and filter
coolant dex cool x2
spark plugs Ac Delco ZR1 - 12371165
idler bracket- 12606501
idler pulley - 12606031
idler pulley - 12606032
S/C tensioner bracket - 12606500
S/C tensioner - 12622452
Tensioner Bracket Bolts (x2) - 11588749
Tensioner Bracket Bolt - 11588742
LS3 Water Pump GXP , Corvette, Camaro - 19180610
