I cant get the number 2 to display properly.
Problem: Write a VBA function to solve for f(x) for different values of x ranging from 0 to 2 with increments of 0.1.
I called a cell I for increment of .1, then used “=cell+i” for 0-2.1. For some reason 2 displays as out of range. I was told its because of ‘phantom digits’ when using non integer values and a solution is to use for loops and integers with division. There has to be a solution using if statements though.
Function hw_3(x)
If x >= 0 And x <= 0.5 Then
hw_3 = 1.2 * x ^ 2
ElseIf x > 0.5 And x < 1.2 Then
hw_3 = 1 - ((1 / 12) * (x - 0.5))
ElseIf x >= 1.2 And x <= 2 Then
hw_3 = Exp(-2 * x)
ElseIf x < 0 Or x > 2 Then
hw_3 = “out of range”
End If
End Function
Any ideas? I can submit it as is since its a known issue so I’m just looking for an solution out of curiosity.
---------- Post added at 01:47 PM ---------- Previous post was at 01:42 PM ----------
I wrote it with an if statement inside of a cell and it worked. wtf.
=IF(AND(B19>=0,B19<=0.5),1.2*(B19)^2,(IF(AND(B19>0.5,B19<1.2),1-(1/12)(B19-0.5),IF(AND(B19>=1.2,B19<=2),EXP(-2B19),“out of range”))))
