Hey guys,
Will USDM (not sure if it makes a difference) 300ZX Calipers fit on a Skyline? and if so, do they provide any advantage. Thanks!
-andres_mt
p.s. For all the skyline owners, where do you guys get most of your parts?
Hey guys,
-andres_mt
Not sure if it matters, but you should probably specify if its a GTS-t or a GT-R.
oh ya its a GTS-t.
I dont see the point as they are very similar in design and performance …possibly if you have a GTS Skyline with 2 piston front calipers then go to 4piston Z32 ones
^ That’s why I kind of wanted to switch. But do they fit on a skyline???
yes but your rotors are different if you have the gts 2 piston brakes
They might work with your stock rotors if you have a GTS-T with the 4 pistons and you buy the correct z32’s.
And they will not work on GTR rotors, you need GTR calipers for that.
Be careful as there are 3 styles of calipers and 2 styles of rotos and 2 styles of pad that Z32’s came with.
K so then I should ask what kind of z32 caliper and what kind of pads he’s got???
anybody know if the master cylinder off of a 300ZX will bolt on directly to a Skyline (GTS-t Type M) ???
