like the title says truck is a 94 just need the solenoid will take the plunger also
need one asap, thanks
You sure it’s the solenoid and not the relay? In a pinch you can turn the key on open the hood and manually open the solenoid. The hold coil will keep it open and you can still drive the truck
Ya I acutally went as far as bench tested the solenoid still nothing, I just removed the whole setup and turned the fuel on manually truck isn’t on the road yet so no big deal
I just freaked out because on rockauto these go for $400 and at napa they are $600 I was like WTF, turns out http://www.genosgarage.com/ has one for $120 just ordered it last night so all is well
