Model year is a 1996, if that matters.
Basically looking for:
s14 M/T transmission
s14 5 speed Driveshaft
s14 M/T harness (Will mod my A/T wiring if I really have to)
s14 M/Ttransmission crossmember
s14 clutch master cylinder
s14 clutch slave cylinder
Clutch hardlines
Clutch rubber line and dampener line
Clutch pedal assembly
S14 Shifter assembly (plate, lower rubber boot, upper leather boot, finisher plate)
s14 96 manual ECU
flywheel backing plate
brake pedal assembly (or I’ll just cut mine if i have to)
Bellhousing bolts for a 5 speed bellhousing
Bolts to hold Pressure Plate to Flywheel
M/T flywheel bolts
I think that’s all, let me know if I’m missing anything.
XSNRGE
2
S13 and S14 clutch pedal assy. interchangable?
If so, I’ve got one.
If clutch master and slaves are the same as well, I’ve got those too…
Stiky
3
if you want some s13 shiT I’ll give you my complete five speed for $250 only problem might be the CMC other than that I got it all
damn so much s13 stuff lol, I gotta look at which items are interchangeable first.
driveshaft and pedal aren’t interchangeable…
Got some of the parts, thanks vlad!
Now here is the remaining parts I need:
s14 M/T crossmember
Clutch hardlines
S14 Shifter assembly (lower rubber boot, upper leather boot, finisher plate)
s14 96 manual ECU
I have some conversion parts that you can use, check this thread: http://www.son240sx.org/forums/showthread.php?t=46506
pmd.
Ok now only looking for:
s14 M/T crossmember
Clutch hardlines
S14 Shift boot in excellent shape
i believe s13junkyard has a pair of s14 brake/clutch pedal assemblies for sale
Bump
s14 M/T harness
s14 M/T crossmember
Clutch hardlines
