I need the lines and reservoir. If anyone knows a good place to pick some up that would help too.
Did you know you can get the 89-90 lines to work? I took mine to a place that makes hydraulic lines and fittings and all they do is cut the hard line out and put a fitting on each end of the rubber lines and connect them. It was pretty cheap too, I can’t remember off hand exactly how much it was though. With the resivor you can mount it on the other side with 2 of the 3 bolts. There should be some rubber plugs you can pop out and use the holes to mount it.
^^ Or you could save your money and mod them for free like I did.
http://www.n-e-c-c.com/forum/viewtopic.php?t=3889&highlight=power+steering
Interesting I must have missed that one. How bad was the bend in the line? Knowing me I’d find a way to kink the line
But yeah that link should be stickied. Good info
guy here in lethbridge that owns a nissan salvage yard/shop will have some lines for you most likely. the name is called Useable used nissan/infinity specialty’s you may look him up if interested.
