Need this whenever I can find one. Mine has a small leak (under pressure) where the cooler is basically compressed together. I was hoping the leak was from the $7 O ring that always dry rots, but I was not so lucky. Car is a 1993 yet I am sure the part will be very similiar if not identical from 90-97.
which part are you talking about? is it located on the back of the block under the intake manifold and the oil filter screws onto it? if you’re talking about the part I think you are, the f22’s didn’t come with it, only the h-series motors.
Well that is the part I am talking about. Do you mean the H22A’s do not have it? I own a 1993 cb7 with an F22A in it and that part is on my car, I watch oil drip out of it at idle onto my exhaust whenever I peep under the car. I know the Oil Cooler is leaking. So if you have the part I would buy it off you.
is this what you’re talking about that you have? vvvvv
i didnt know they came on the f22a’s. you could always check m&m u-pull it. they usually have a 90-93 accord. you could call ahead and ask or i’ll look and see if they have any when i’m there in the next few days …
That is part. The seem (sort of) directly behind the lower coolant line in your pic is what is leaking on mine. Pisses me off. I actually wonder how it cracked or seperated.
But if you see it there that would be sweet, I hate oil leaks, I never had a problem with my DSM leaking, which is pretty rare, so the fact that my honda has issues just sorta makes me laugh. Let me know if you see one there.
