WTB: auto -> 5spd swap parts
I think I should start getting all of the parts I need together before winter hits so I can get this stuff done before I hace to park it. The parts I need are the following (preferably parts from an s14 but doesn’t have to be):
-s13/s14 manual tranny
-shifter
-release bearing
-pressure plate
-clutch
-manual flywheel
-manual mounting plate
-manual flywheel bolts
-clutch pedal
-brake pedal
-clutch master resevoir with cylinder
-clutch slave cylinder
-clutch hydraulic lines
-drive shaft
-adapter bolts and nuts for mounting crossmember to 5spd
-reverse, neutral, 5th gear sensor
-shift boot and finishing plate
Looks like thats pretty much all of it. If you have these parts or can point me in the right direction that would be appreciated.
I have a shifter from an S13. $10.
I have an S13 parts car with all that… cept the engine, and the clutch is gone too…
Give me a call 221-4046. If you can take the car away… then you can have everything for cheap!
Jeff
Hmm im interested in that parts car. i dont know what id do with it when im done with all of the parts though. Can I go over and rip out what I want instead or do you really want it gone? How much do you want for the entire thing anyways?
how much would u pay for everything? i think i can scrounge it all up?
shoot me an offer
bump. people i am rounding these parts up NOW so if you have a parts car or these parts laying around pm me
I still have everything?
