WTB Oil scavenge pump, new or used. dont matter. thanks
do ya mean a vacuum pump so ya dont get so much blow by
no for turbo return line… are you talking about for crank case vent?
thats what i thought ya meant lolol
http://www.turbowerx.com/Scavenge_Pumps/Exa-Pump/Exa-Pump.html
Best unit I’ve used for transmission and diff cooler setups but would work for oil too.
the trick is finding one that can work the high temps of the fluid. That one is good for ~350F
-Adam(Boxersix) on JVGs kompewtyr
thanks for the info boxersix, thats the one i was looking at, for you or anyone else who has used one of these, will i need to run a reservoir from the turbo before the pump to let oil collect before its pumped back into pan or no? JUst reading and some say depending on the setup the oil bubbles when it moves too quickly so the resevoir would let it collect then get pumped rather than pulling directly from the turbo. thanks in advance
You will want a small(roughly 1 pint) size collection tank off the CHRA to allow the oil to pool before the scavenge picks it up. Similar to the stock tanks on 911 turbos
964 turbo:
996/997 turbo:
nice! thanks for the pics. exactly what i was lookin for. Edit*
