i’m looking for some cheap parts for the honda project. did i say cheap?
-turbo timer
-hood pins
-oil pressure gauge
-d16 turbo manifold
-35/38mm wastegate
-manual boost controller
-vacuum line
-turbo timer
-hood pins
-oil pressure gauge
-d16 turbo manifold
-35/38mm wastegate
-vacuum line
i have apexi turbo timer 40 bucks… and a oil pressure gauge but none of the fittings for it 20 bucks id say good bye too it never used either .
i have a bunch of vaccum line?but so does autozone
Only if you like shit hose. Talk to innovative or STM for actual vacuum line that won’t close up under vacuum and balloon out under boost.
you’re retarded mark. i’ve built setups running 25+ psi that NEVER had a problem with autozone hose.
“make sure you buy the most expensive hose possible for your junkyard turbo kit” come on.
to the OP- use autozone vac hose, its the cheapest way to go. what turbo are you gonna end up using? and are you looking for an HF manifold or a real deal one?
im running a t3/t4 .70 trim with a .42 exhaust side. im in the process of looking for a manifold.
what kind of gauge? any pics?
hood pins are $10 at advance auto
no shit, i’m gonna go pick some up tomorrow, thanks!
i have a slowboy racing manual boost controller brand new. 40 bucks?
have any pics?
not of my actual one i dont think but heres what it looks like
my photobucket is being a pita heres the pic tho
I have a gredy turbo timer $30
