looking to get my ecu rechipped, returned to stock. its a p06 with a basemap tune on it. i would like to do it sometime on thursday between say 2 and 5 let me know
turbo setup not workin too well?
/\ you can has chipped ecu.
what tune would you like on it? Is the motor it’s controlling stock?
I just need to know a few things and I can have it for you in no time at all.
Things I need to know:
motor
injectors (stock, dsm, etc)
map sensor (stock, motorola, gm)
knock sensor (present or not)
what rpm you’d like vtec to engage at
rev limiter (higher or lower than stock if you want)
no lift to shift
launch control
Why not just disconnect the one resistor? it returns it back to stock by not even connecting to that part of the circuit board
^^ exactly… cut j10 i believe and it will go back to stock settings
it’s j1 that needs to be cut.
but if he wants shit like launch control, vtec point, rev limiter changes, etc. I can use a stock map and add that shit.
