FS: Honda Racing Parts
I have a BRAND NEW MSD IGNITION modified distributor cap for a
Honda Civic 1.5/1.6 liter motor WITH VTEC asking $40
Convert the Honda distributor to accept a powerful MSD coil.
Each cap has a coil tower that connects to an external coil.
A new rotor ensures that the high voltage is delivered to each terminal.
These new Modified Honda Cap and Rotor Kits will help fire up a Honda’s ignition and performance. The most important feature of these caps is the external secondary tower which accepts high voltage from a powerful external coil. This bypasses the weak factory coil that is buried inside the distributor.
Each Kit is supplied with a new rotor to make sure the high voltage is distributed to each of the brass terminals of the cap. To adapt the distributor to the new coil terminal, we include a new 8.5mm coil wire along with a boot, terminal and a handy Mini-Stripper-Crimper tool to get the job done.
I also have a set of AME True Time cam gears
They are BRAND NEW there is two of them and they are for a DOHC Honda motor.
Asking $80. They are $105 each new at summit racing.
Cam Gear, Tru-Time Adjustable, Billet Aluminum, Red Anodized, for use on Honda®, Civic/Civic Del Sol.
Tru-Time adjustable cam gears allow you to get maximum performance out of your engine by advancing or retarding cam timing in precise, one-degree increments. That’s especially useful for heavily modified engines. They’re CNC-machined from 6061 T-6 billet aluminum and have precision-cut, hard-anodized gear teeth. They also have laser-etched markings on the leading edge of the gear, in one-degree increments for easy adjustment.
http://i22.photobucket.com/albums/b327/tinyrally_1971/Tinyrally/for%20sale/DSCF5300.jpg
http://i22.photobucket.com/albums/b327/tinyrally_1971/Tinyrally/for%20sale/DSCF5303.jpg
http://i22.photobucket.com/albums/b327/tinyrally_1971/Tinyrally/for%20sale/DSCF5304.jpg
http://i22.photobucket.com/albums/b327/tinyrally_1971/Tinyrally/for%20sale/DSCF5305.jpg
should make them pic smaller :tup: GL
cam gears for sale still ?
VETCH!
glws
ASS
Yes they are.
y does the one cam gear look faded??
looks dusty
great prices
Lighting?
How do I know.
Crappy 1mp camera?
Quit busting my balls and someone buy them.
whoa son, chill i asked a question. good answer
Honda’s factory ignition is weak?
bump for you anyway.
only once your making over like 700hp.
Edit the first ad to reflect that the parts are for a honda with Vtec and not a Vtech cordless phone.
Can you also specifiy which dohc honda engine the gears are for?
dohc D series? B series? h22a?
Bump for good price.
D series motor
This is starting to be a bigger pain than it’s worth
bump before I go on vacation
Bump, going to Buffalo on Sunday if someone up there wants them.
New price $40 for the Cap, and $80 for the Cam Gears
bump
ill take the cam gears
