** Please fill in all the fields before creating the thread **
** NOTE: Doing a Preview will remove your SUBJECT so re-add it before posting **
Will Ship?: Y
Contact Info: tarach99@hotmail.com
Nissan 240SX
Fidanza S13 SR20 adjustable Cam Gears - 150.00
Red, brand new
Injen Cold Air Intake - Used, black in color, for KADE 95-98. It was originally for an S13 but I had to slightly modify it to make it work (read cut some pipe so it fits in the fender well). It works 100% and just recently came off my brothers car. 150.00
SR20DET oil pan protector/cover - 40.00
Helps prevent denting of stock oil pan
Honda Accord/Prelude
Skunk2 Stage 1 Pro Cams - 450.00
They were installed in my motor for literally 2000KM and then I melted my piston. I’ve since gone to S2 stage 2 cams because I didnt like the way they idled. They made good power (191whp/160tq) on my I/H/E h22a. If you are looking for awesome midrange then these cams provide that.
These cams are meant for weekend cars more than daily drivers and they will require a valvetrain upgrade and a tune.
OEM Honda Timing belt Parts I didnt use when I did my t-belt swap. Bought directly from the dealer. - 80.00 FOR EVERYTHING
Adjuster Pulley - paid 66.59
Main t-belt pulley - paid 58.88
Auto Tensioner - paid 75.67
balance shaft retainer - paid 4.12
UNIVERSAL
K40 Radar Detector - RD850 Radar/Laser Detector. Top of line unit. Search for more info. - 150.00
Stewart Warner Fuel Pressure Gauge - 40.00
Mechnical, 52mm, brand new
Crane Cams Hi-6R Ignition System - 200.00
Brand new, rev limiter and 0-20deg or timing retard. Perfect for boosted NA engines.
Blitz R-VIT i-Color for Toyotas - 200.00
The BLITZ R-VIT i-Color is a monitoring multi meter designed for 2003 or later Toyota CAN-bus or vehicles equipped with 1996 or later ISO14230 diagnostics connector. Installation is simple, it is install just by connecting to the vehicle diagnostics coupler. It features a 65,000 Color LCD screen and multi angle display. It can be set on three different angles depending on the location of the installation. The BLITZ R-VIT i-Color monitors a maximum of 29 items and able to display 6 monitored items simultaneously. Monitored items are: Speed, RPM, Water Temp, Ignition Timing, Fuel Injection Time, Air Flow Voltage, Outside Temp, Intake Manifold Pressure, Boost, O2 Voltage, O2 Rear Voltage, AF 1, AF 2, Intake Air Mass , Battery Voltage, Throttle Output, AT Temp, Gear Position, 4WD Ratio, Fuel Pressure, Momentarily Fuel Consumption, Malfunction Diagnosis Code, Lock Up ON ·OFF, External Voltage Input (Press, A/F Box) / External Temp Input, Fuel Pressure Control, Fuel Injection Control / Electric Fan Control, etc.
Nitrous Pro Flow 10lb bottle - 150.00
Brand new
SAGE Performance Fuel Rail Kit for WRX - 75.00
No name kit but machining looks excellent.
(2) SONY XVMH65 6.5" Headrest Monitors - 550.00
INFO: http://www.crutchfield.com/S-FrnODBGt1x3/App/Product/Item/Main.aspx?i=158XVMH65
Kyosho Turbo Raider RC Car - 100.00
This is a classic 1/10th scale RC car from the 90s. Has typical wear marks. Comes with a pistol grip controller, battery charger. You will need a new battery for it.
I’ve got more photos if you are interested.
RandomTech hiflo 2.5" cat for a 90-94 FWD turbo Talon/Laser - 100.00
Has some minor surface rust but make no mistake this cat is still in very good shape. Only used on my Talon for a year.
Asking Price: $ (OBO)
Condition: New/Used
Will Ship?: Y/N
Contact Info: Send PM for contact details and to schedule a meet
Description:
