034 Motorsports Poly Snub Mount with Bracket.
$65
Brand New never used or installed.
http://www.034efi.com/images/SnubAndBracket.jpg
Snubber bracket and poly mount kit, fits most 5-cylinder cars, greatly  reduces engine movement w/o increasing ride harshness. A dramatic  improvement for the investment. Poly mount fits very tightly in bracket  to reduce any slop from the drivetrain.
Fits 4000 Quattro, 80/90/Coupe Quattro, UrQuattro and others.  Does not  include brackets for Aux radiator, if you are still using it brackets  can be easily fabbed up using some strap aluminum.
<i>NOTE: When installing this poly mount in an 034Motorsport Snubber  Bracket, some light trimming of the outside of the mount is required to  make it a perfect fit, this can easily be accomplished with a utility  knife.</i>
