180sx spun a bearing, so Im parting out. heres the list of goods, prices will be up later. please pm with offers only if serious in purchasing the items. sick and tired of people wasting my time.
stuff sold:
-t25
-chuki turns sigs
-greddy boost gauge
-starter
-wiring harness
-tranny harness
-t3/t4 manifold
-apexi intake
motor brackets
oil dip stick and tube
motor/trans divider plate.
ka to sr rad hose
180sx side markers
cat
external wastegate
injectors/rail
cas cover
coilpacks
180sx brakes
cas
knock meter
fmic
turbo timer
3. S13 GAB Shocks w/ RSR springs…$350 shipped very rare, dampening is 6 way adjustable and rsr are the lowest springs I ever seen, way lower then any other lowering springs on the market.
more pics: http://img233.imageshack.us/img233/6448/180sx010nd3.jpg , http://img118.imageshack.us/img118/6392/180sx011gb6.jpg , http://img233.imageshack.us/img233/8222/180sx012ot1.jpg
4. sr20det oem clutch fan…$40 shipped best/most reliable cooling method in my opinion.
7. s13 sr20det maf…$80 shipped very mint
8. oem sr20det rubber intake pipe…$35 shipped
11. s13 sr20det redtop 62 ecu…$150 shipped
12. R32 GTR seats…$450 + shipping seats are a little worn, cat not included
right >
left >
15. custom turbo elbow made for t4 turbo top mounted, bolts up to turbo then oem dp…$40 shipped
17. sr20det radiator…$100 shipped no bent fins, mint
18. S13 Digital Climate Control $100 shipped
19. sr20det ignitor…$75 shipped
26. HKS EVC 3 Boost Controller…$200 shipped comes with everything needed to install, mint condition
31. sr20det alternator with all brackets…$130 shipped
33. Redtop Valve cover…$70 shipped
34. sr20det stock exhaust manifold…$40 shipped
35. sr20 oem used pressure plate + clutch…$55 shipped
36. S14 SR t28 turbo lines…$25 shipped (minus 1 coolant line, comes with all neded bolts/fittings, not shown in pic)
38. cusco brake master cylinder stopper…$60 shipped
39. S13 5 Speed ABS driveshaft…$120 shipped
40. SR20DET power steering pump & brackets…$100 shipped comes with everything need to install the pump, brakcets, adjustment screw,etc
41. F1 RACING sr20det stage 3 clutch kit…$80 shipped
more pics: http://img227.imageshack.us/img227/7060/180sx4003cf6.jpg , http://img146.imageshack.us/img146/2435/180sx4004jm6.jpg
42. Circuit Sport Subframe Collars…$65 shipped
44. 180sx/s13 tranny mount & crossmember…$60 shipped
47. 180sx Gauge cluster, 41k…$40 shipped.
49. razo shift knob…$20 shipped
50. SSR Radiator Cap…$20 shipped
52. 300zx front PBR Brake Pads…$50 shipped Brand new in box
55. sr20det redtop block… not sure about price yet spun a bearing and blew a piston ring. comes with all internals.
56. sr20det stock intake manifold…$70 shipped comes with the gaskets
57. sr20det throttle body…$60 shipped
58. sr20det TPS…$60 shipped
60. sr20det oem flywheel…$60 shipped resurface reccomended
61. sr20det knock sensor…$25 shipped
63. Sr20det T25 Turbo…$200 shipped in great shape, boosts hard. litterally no shaft play
64. sr20det T25 stock turbo lines…$30 shipped
65. sr20det 370cc injectors x 4…$100 shipped in excellent shape
66. APEXI Filter Kit w/ adapter designed for sr20det…$100 shipped very good condition barely used
67. s13 tranny harness…$50 shipped
68. HKS adjustable actuator for t25…$80 shipped will also fit t28 just need to drill mounting holes.
69. Megan racing manifold…$100 shipped bottom mount for sr20det, has a crack
70. oem sr20det turbo eblow…$30 shipped has the fitting for redtop o2 sensor.
71. s14 sr20det o2 sensor…$30 shipped
