****LIST UPDATED!
180sx spun a bearing, so Im parting out. heres the list of goods, prices will be up later. please pm with offers only if serious in purchasing the items. sick and tired of people wasting my time.
stuff sold:
-t25
-chuki turns sigs
-greddy boost gauge
-starter
-wiring harness
-tranny harness
-t3/t4 manifold
-apexi intake
motor brackets
oil dip stick and tube
motor/trans divider plate.
ka to sr rad hose
180sx side markers
cat
external wastegate
injectors/rail
cas cover
coilpacks
180sx brakes
cas
knock meter
1. FMIC w/ piping, couplers and bov…$275 shipped
pics of it installed here: http://img154.imageshack.us/img154/5585/180sx001xe3.jpg , http://img154.imageshack.us/img154/7014/180sx002vh5.jpg , http://img118.imageshack.us/img118/2626/180sx003im9.jpg , http://img154.imageshack.us/img154/6694/180sx006kv3.jpg , http://img154.imageshack.us/img154/3317/180sx007qv4.jpg , http://img233.imageshack.us/img233/1620/180sx008yv4.jpg
3. S13 GAB Shocks w/ RSR springs…$350 shipped very rare, dampening is 6 way adjustable and rsr are the lowest springs I ever seen, way lower then any other lowering springs on the market.
more pics: http://img233.imageshack.us/img233/6448/180sx010nd3.jpg , http://img118.imageshack.us/img118/6392/180sx011gb6.jpg , http://img233.imageshack.us/img233/8222/180sx012ot1.jpg
4. sr20det oem clutch fan…$40 shipped best/most reliable cooling method in my opinion.
7. s13 sr20det maf…$80 shipped very mint
8. oem sr20det rubber intake pipe…$35 shipped
11. s13 sr20det redtop 62 ecu…$150 shipped
12. R32 GTR seats…$450 + shipping seats are a little worn, cat not included
15. custom turbo elbow made for t4 turbo top mounted, bolts up to turbo then oem dp…$40 shipped
16. oem sr20det boost solenoid…$20 shipped allows you to run 10 psi when its hooked up
17. sr20det radiator…$100 shipped no bent fins, mint
18. S13 Digital Climate Control, complete with all sensors/harness’s…$150 shipped
19. sr20det ignitor…$75 shipped
25. Turbo Timer w/ s13 harness…$50 shipped plug and play, no idea what brand it is.
26. HKS EVC 3 Boost Controller…$200 shipped comes with everything needed to install, mint condition
30. Brand new HKS style air filter w/ maf adapter…$45 shipped brand new, never used hks style mushroom filter and alum adapter.
31. sr20det alternator with all brackets…$130 shipped
33. Redtop Valve cover…$70 shipped
34. sr20det stock exhaust manifold…$40 shipped
35. sr20 oem used pressure plate + clutch…$55 shipped
36. S14 SR t28 turbo lines…$35 shipped (minus 1 coolant line, comes with all neded bolts/fittings, not shown in pic)
38. cusco brake master cylinder stopper…$60 shipped
39. S13 5 Speed ABS driveshaft…$120 shipped
40. SR20DET power steering pump & brackets…$100 shipped comes with everything need to install the pump, brakcets, adjustment screw,etc
41. F1 RACING sr20det stage 3 clutch kit…$90 shipped
more pics: http://img227.imageshack.us/img227/7060/180sx4003cf6.jpg , http://img146.imageshack.us/img146/2435/180sx4004jm6.jpg
42. Circuit Sport Subframe Collars…$70 shipped
43. sr20det a/c compressor, belt and brackets…$70 shipped
44. 180sx/s13 tranny mount & crossmember…$60 shipped
45. sr20det water pump…mint…$50 shipped
46. 180sx rear calipers, pads(lots of life) and lines…$70 shipped
47. 180sx Gauge cluster, 41k…$50 shipped.
48. b&m shift knob $20 shipped
49. razo shift knob…$20 shipped
50. SSR Radiator Cap…$25 shipped
51. Empi tie rod boot…$20 shipped Brand new in box
52. 300zx front PBR Brake Pads…$50 shipped Brand new in box
53. 180sx 6 bolt VLSD w/ axles…$275 shipped mint condition with only 100k
54. sr20det redtop head…$175 shipped complete with cams, lifters, etc…
55. sr20det redtop block… not sure about price yet spun a bearing and blew a piston ring. comes with all internals.
56. sr20det stock intake manifold…$80 shipped comes with the gaskets
57. sr20det throttle body…$60 shipped
58. sr20det TPS…$60 shipped
59. sr20det redtop Idle Air Control Valve…$60 shipped
60. sr20det oem flywheel…$60 shipped resurface reccomended
61. sr20det knock sensor…$25 shipped
62. battery relocation kit…$70 shipped comes with metal mount, bungy cord, and plenty of 0 gauge wire.
