FS Item(s) Description:
Car fires and runs, need few little things to finish
Will part car once chassis sells
car comes with all moldings and front bumper just not pictured
cars a little dusty from underground heated storage
Motor + Transmission
-B16A2 came out of a SIR with 90,000km
-Matching SIR transmission
-Matching ECU with spoon chip
-Polyurethane motor mounts
-Full stainless 3” V-band exhaust, Magnaflow cat, Magnaflow muffler (Receipt available)
-BRAND NEW STR 68MM throttle body
-BRAND NEW Exedy Clutch (paid 230$ have receipt)
-Lightweight flywheel – Just Resurfaced NEVER DRIVEN
-SIR radiator
-BRAND NEW upper and lower radiator hoses
-BRAND NEW ECU conversion harness
-Tucked engine harness
-BRAND NEW hasport EF b-series shift linkage
-BRAND NEW energy suspension shifter bushings
-REBUILT drive shafts
-Rpm intake tube, heat wrapped (because race car)
Suspension
-JIC sport DC-2 type R coilovers (approx 80,000km)
-OEM Type- R rear control arms (bushings in good condition)
-SIR front sway bar
-23mm Type-R rear sway bar with end links ( bushings in great condition)
-BRAND NEW skunk 2 front camber kit
-BRAND NEW Ingalls rear camber kit
-BRAND NEW Megan rear toe links
-BRAND NEW Megan rear strut bar
-BRAND NEW front inner+outer tie rods (both sides)
4 x 114.4 brake conversion
-All calipers + brackets were stripped and painted
-BRAND NEW ARP studs all the way around
-BRAND NEW Muteki lug nuts
-BRAND NEW Russel braided brake lines
Front
-Jdm crx knuckle machined out to accept larger wheel bearing and 4 x 114.4 spindle
-BRAND NEW wheel bearings
-BRAND NEW brake pads + extra set
-Prelude SRV rotors(11.5inch) freshly machined
-Professionally re-assembled by head mechanic at Meadowvale ford
Rear
-Fresh pads
-Freshly machined rotors
-Rear trailing arms stripped and freshly painted
-4 x114.4 Type- R rims with decent falken tires for got which ones.
Interior
-1 party mix recaro ( pretty rare,1 cig burn from previous owner)
-1 all black recaro
-Weighted shift knob
-Generic short shifter
-JDM EF steering wheel
-SI interior – had 60,000 km when pulled out of other car
-FRESH black carpet
- RED ctr mats
Chassis
-NO RUST
-All wheel wells stripped and recoated + underneath recoated
-Floors on inside freshly painted with truck bed liner
-All brackets and covers on interior painted black
-EF-9 front clip (missing bumper)
-Si front bumper (black,off car)
-Rear color matched bumper + Spare rear bumper (black)
-SIR rear trunk lid
-Car was painted 2.5 years ago, paints still fresh
-Quarter panels changed with fresh metal when painted
-BRAND NEW brake lines
-BRAND NEW Fuel Tank assembly
-walbro fuel pump
-spare taillights
Asking Price:
5,800$ WITHOUT RECAROS.
4,000$ take it all before next week.
2,500$ everything but drive train
Mainly looking to part.
Don’t call me and tell me what else you can buy or what your buddy can get you, i don’t care.
Contact:
- 416 994 6595
call or txt at anytime with any questions.
great fun little cars glws
