This is a 95% rust free rx7, it is bubbling up around the rear quarter panel about the size of a quarter. The sunroof is rusted, however i have a replacement panel and a sunroof motor that will go with the car. The rear has a few paint cracks and the spoiler was removed. (sun roof does work, but needs some help sometimes)
(video here: http://www.youtube.com/watch?v=e0rrCmLkZvI)
The engine was rebuilt, it has 32k miles on it since rebuild Compression is good, lowest rotor face is 95psi they are all within 10 psi of each other i measured this once i got the car running.
I have a set of OEM fog lights to go with it, and JDM selective yellow bulbs
The car currently has snows on the rears, and questionable quality fronts [ATTACH=CONFIG]19328[/ATTACH][ATTACH=CONFIG]19327[/ATTACH][ATTACH=CONFIG]19326[/ATTACH][ATTACH=CONFIG]19325[/ATTACH][ATTACH=CONFIG]19324[/ATTACH]
dumb question, but what air meter is on that the plastic or aluminum? i know the metal one has a fuel switch inside and those style air meters are always bad, i used to have a stack of the rx7 b codes around for reasons like that…
ok i apparently i cant read i missed where you have fuel presure. i had one at work doing this before, let me think if i can remember wtf i did to it
try car-part.com if you dont mind buying used shit, they got air meters as low as 30 and ecus for a little bit more. ive yet to get a bad part from them
I’m looking for a winter project and a fun summer car but. . . How current are these pictures??? The plates are crazy old, and the leaves are still green . . . when was the last time it was on the road?
it was on the road driving 4 days ago, And then these problems started… those are the plates i put on it to avoid being towed when i first got the car here before i registered it at the beginning of the month.
The pictures were taken about a week to 10 days ago if i remember correctly
If it had the spoiler on I’d take it. J/K
This thing looks super clean. Shocked you’re selling it if it’s down to a few fairly minor issues. I’d say keep it but I dunno your situation of course.
GLWS
I’ve exhausted every resource i have. The last resort is to check it out with another maf which i will hopefully do today if that doesn’t fix it i’m just going to put it in storage if nobody buys it.
Hey robftw, appreciate the dibs on it. If I wasn’t planning trips and such, this would already be sitting in my back garage. Hope you find a good home for her.
