PLEASE EMAIL QUESTION TO: mild2wildracing@gmail.com
This car is fun, easy to drive and has low running/maintenance costs.Please feel free to ask any questions you may have, the car is in great condition and ready to drive at track days or in competition.
1996 Nissan 240sxCar Weight 2441 LBS
– Engine / Drivetrain –
2006 VQ35DE 16000km (When Swapped)APS Tall-Boy Balanced Distribution Inlet Plenum (Powdercoated Wrinkle Black)Jim Wolf Technology Camshaft Kit (G8)Jim Wolf Technology Valve Spring & Shim Kit A3503-SPRNGOEM Nissan R35 GTR InjectorsNWP 75mm Big Bore Throttle Body KitPhenolic Thermal Intake Manifold Spacer KitNissan 350z ECU w/ UPRev Tuned By Innovative TuningInjen Technology SP1986P Polished Mega Ram Cold Air Intake SystemVibrant Performance 7" Air Filter #10961Vibrant Performance Bellmouth Velocity Stack, 4" Inlet O.D. x 7" Bellmouth O.D.SG Stainless Steel Long Tube VQ35 Headers for S14 240sxTomei Titanium 3” Mid Pipe and Axle BackMild2Wild Racing Stainless Steel “Y” Pipe (Manifold Collectors to Titanium Mid Pipe)NISMO Oil Pump VQ35DE 15010-RRZ30Mild2Wild Racing Radiator Surge TankMild2Wild Racing Oil Catch CanCSF Aluminum Radiator #CSF2870Mild2Wild Racing Radiator Shroud w/ Dual SPAL Fans
Nissan 350z CD009 6 Speed Transmission ~79,000kmOS Giken Super Single Clutch [SP SINGLE] Aluminum Cover NS111-AB8OS Giken Hydraulic Release BearingSingle Piece Custom DriveshaftDifferential - 4.08 Final Drive, Stock Nissan 240sx Case, OS Giken Super Lock LSD 1.5 way (adjustable)Tilton Engineering Differential Oil Pump (Automatic Cycle Control by MoTeC C127)Setrab 50625-7612 Differential Oil CoolerDifferential Cooler Oil Lines Vibrant Performance AN- Fittings
McKinney Motorsports Engine MountsMcKinney Motorsports Transmission MountMcKinney Motorsports Shifter HousingMcKinney Motorsports 350z Swap HarnessSetrab 50119-7612 Power Steering Cooler
– Interior / Body –
Kirkey 71300 Standard 20-Degree Layback Road Race Containment Seat w/ Kirkey 71311 Black Tweed Seat CoverRacequip #755005 6-Point Euro Style HANS/HNR Shoulder Harness with Camlock (Driver)Custom Mount for Kirkey Seat to Nissan Chassis w/ Roll Cage Tie InSparco Sprint Passenger SeatRacequip #711001 5-Point SFI 16.1 Latch & Link Harness Set (Passenger)Center Console Blanking Plates w/ Push Button Start and Aerospace Circuit BreakersSparco Steering Wheel Quick Release #015R98TUSparco Competition R325 Leather Steering Wheel6 Point Welded Roll Cage w/ Door Bars (1.5” x 0.120" DOM)Aluminum Rear Firewall, 2 Piece, Removable (Back side of main hoop) by Hitman Hotrods - 3M DiNOC Carbon Look VinylMild2Wild Racing Removable Tubular Front End
Carbon Fiber “F1 Style” Side MirrorsMild2Wild Racing Front Splitter / UndertrayMild2Wild Racing Dive PlanesMild2Wild Racing Composite Headlight Delete PanelMild2Wild Racing Composite Cowl Hood w/ Aerocatch (Type 1) Latches (Quantity 4) and LongAcre Hood Pins (Quantity 2)Mild2Wild Racing Aluminum Radiator VentMild2Wild Racing Gutted OEM Nissan Doors (Skin w/ Handle/Latch Only)Mild2Wild Racing Carbon Fiber NACA Duct (Quarter Window) for Differential Cooler FeedMild2Wild Racing Carbon Fiber Rear Window w/ Dzus fastenersMild2Wild Racing Carbon Fiber Trunklid w/ Aerocatch (Type 1) Latches (Quantity 4)Mild2Wild Racing Lexan Quarter WindowsKognition Racing 70" Carbon Fiber Wing w/ Aluminum Chassis MountsExtreme Dimensions Front Bumper - Modified w/ Aerocatch (Type 3) Latches (Quantity 2)Extreme Dimensions 25mm Composite Front Fenders - ModifiedExtreme Dimensions 20mm Composite Rear Over FendersExtreme Dimensions Composite Side Skirts - ModifiedOEM Nissan S14 Rear Bumper - ModifiedEx-NASCAR Sprint Cup Carbon Fiber Oil Cooler Duct (Differential Oil Cooler)
Racequip Front Tow StrapRacequip Rear Tow StrapLongAcre Helmet Hook
PLEASE NOTE Radio Equiptment Pictured (Storage Bin, Wiring, Button, Antenna, Curly Cord) Is NOT included.
– Brakes / Suspension / Wheels –
Extended ARP Wheel StudsRAYS Engineering Lug NutsOEM Nissan 350z Brembo Brake Calipers (Front and Rear)Project Mu Two Piece Slotted Front RotorsNissan 350z Brembo Rear RotorsHawk DTC-70 Pads (Front)Hawk DTC-60 Pads (Rear)Stainless Braided Brake Lines (Front and Rear)K-sport Hydraulic Emergency Brake (Plumbed Inline to Rear Brakes)HSD Nissan S14 MonoPro Coilovers w/Camber Plates and Rear Top Hats
SPL Front TC RodsNISMO Front Lower Control ArmsTEIN 350z Inner Tie RodsSPL PRO V4 Front Outer Tie Rod Ends S13/S14
SPL Rear Toe ArmsSPL Rear Upper Camber ArmsSPL Rear Traction ArmsSPL Solid Subframe BushingsSPL Solid Differential BushingsSPL FKS Rear Knuckle Monoball Bushings for S14Powered By Max Rear Lower Control Arms
Mild2Wild Racing Strut Tower Brace w/ Firewall Tie InSIKKY Manufacturing 32mm Front Sway Bar (Spherical End Links)Progress Suspension 24mm Rear Sway Bar (Spherical End Links)
Enkei Racing RPF1 Special Brilliant Coating 17" x 9.5" ET+18 Front WheelsEnkei Racing RPF1 Special Brilliant Coating 17" x 10" ET+18 Rear Wheels
– Fuel System –
ACCEL Fuel Pressure Regulator #74567Dual Walboro 255 Inline Fuel Pumps10 Gallon Fuel CellMild2Wild Racing Aluminum Swirl PotVibrant Performance AN-6 Fuel LineMagnaFuel Fuel Filter
– Electronics / Data –
MoTeC C127 7" Color w/USB-C127 I/O Unlock-C127 Enable Logging-10hz GPS-RaceGrade Flying Lead Harness-RaceGrade I/O Expansion Harness-Custom Programming
RaceGrade 100 PSI Oil Pressure Sensor (M APT-G2-DTM-100A)RaceGrade 200°C Oil Temperature Sensor (M 25-2197 D)RaceGrade 200°C Transmission Oil Temperature Sensor (M 25-2197 D)RaceGrade 200°C Differential Oil Temperature Sensor (M 25-2197 D)RaceGrade 100 PSI Fuel Pressure Sensor (M APT-G2-DTM-100A)RaceGrade 2000 PSI Brake Pressure Sensor (M APT-G2-DTM-2000)OEM 350z Water Temperature Sensor (Transmitted via CAN to C127)AEM Uego Wideband O2 Sensor Gauge and Output to MoTeC
Antigravity YTX12-24 Lithium Battery (6lb total weight) Relocated Under DashboardBattery Terminal Extensions on Dashboard for ChargingAfterburner FIA Rain/Brake Light #1315-001
Asking Price : $22,000 CADFree Delivery within the Greater Toronto Area, delivery to other locations can be arranged at the buyer’s expense, or pickup can be arranged.
[ATTACH]37399[/ATTACH]
