Looking to buy some solenoids to eliminate or fix the shifting problem I’m having . Anyone have some laying around ?
Check m&m they have a bunch of civics
don’t know what your actual shifting problem is…but I’m going to doubt its the shift solenoids. If you are scanning your codes and are getting the ones for the shift solenoids, there is a really good chance that isn’t your problem. check your underhood fuse panel for a blown fuse, I believe its in the top row closest to the firewall. But for what its worth check them all. There is a TSB on these for the wiring and the way its mounted under the intake manifold. The connectors/wiring gets messed up and it will blow a fuse and make your car not shift correctly.
now if/when that works, you can paypal me a few hundred bucks.
