1G DSM AUTO AWD Part Out(Gauging Interest)
Electronics/Tuning
91-94 DSMLink V2.5 w/ECU-$475
AEM UEGO Wideband-$150
91-94 TCU (need to check if EPROM before price listed)
91-94 AUTO ECU-$50
Fuel
Walbro 255-$50
Fuel Lab AFPR w/line and gauge-$140
RC 550’s w/ new seals-$130
Powdercoated fuel rail w/-6AN fittings-$30
Drivetrain
AT AWD Trans (unsure of mileage, shifted fine)-$400 picked up, $500 shipped
AT Transfer Case-$100 picked up (can ship)
Front axles with intermediate shaft (new boots)-$100+shipping
Rear axles-$100+shipping
4 bolt rear-$200+shipping
Suspension/Wheels
KYB adjustables with Eibach Springs-$300
Kyowa Racing wheels w/tires-$300 picked up
Turbo/Exhaust
2.5" Buschur Exhaust w/ brand new gaskets. Comes with test pipe and catalytic converter-$300 picked up (too big to ship)
B16G just rebuilt with only 547 miles on it, will come with oil feed and return line, 2G mani, 2G O2 housing and new gaskets-$425 shipped for it all
Engine
Head
-3 angle valve job
-decked, cleaned
-pressure tested
-3G lifters
-EVO VIII springs and retainers
-Ferrea Competition Valves
-No stripped bolt holes at all!
-ARP exhaust studs
-Powdercoated stock cam gears
I do have the receipt
-$550 shipped
Timing
-OEM Timing Belt
-OEM Tensioner
-OEM Idler Pulley
-OEM Tensioner Pulley
Only have idle time on them
$140 shipped
Shortblock
Newly rebuilt with used OEM pistons
-OEM rings
-ACL Bearings
$300
New AT starter-$70
Cooling System
-Stock Radiator with fans-$50
-Stock Hoses-$25
-Powder coated T-stat housing-$45
-New rad cap
-New gaskets
-New T-stat
-Powder coated Water pipe-$35
-New Water pump-$40
Miscellaneous
Mitsubishi Valve Cover powder coated SD Wet Black-$100
Shaved Valve Cover powder coated Mirror Red (1 broken bolt hole)-$60
Engine Harness-$75
Fusebox Harness-$75
Powder coated Intake Manifold (SD Wet Black/Mirror Red Lettering) will come w/ thermal gasket-$80
Powder coated Forced Performance Intake pipe with couplers (SD Wet Black/Mirror Red Lettering)-$90
2G MAS-$40
Hallman MBC-$60
Any other things you may be interested in just PM me. I have a ton of parts on here that are powder coated so let me know if you would like to get rid of your ugly rusty parts for some nice powder coated ones for cheap. Thanks for your interest.
TTT
Do you have any pics of the shaved red vc?
It’s not as perfect as it shows in the pictures since coolant got sprayed on it but it should clean up nicely. The timing belt side spark plug cover bolt hole cracked off but it did not crack through the valve cover, no leaks on it at all.
It is now being parted, my father offered me a killer deal so this has to go.
I will probably be in need of parts soon as I delve into my gsx. Just letting you know haha.
Sounds good just let me know what you need. I can give you a deal if you need a lot of things since you aren’t too far away.
AFPR, throttle body, fuel rail are sold. KYB/Eibach pending
Transfer case gone, longblock pending.
