2000 Integra GSR Benson Sleeved GT3076r project
We are just finishing up this project. The car should be on the dyno monday.
The car has a benson sleeved block at 83mm assembled in house.
cp 9:1 pistons
manley rods
oem honda crank
acl bearings
skunk2 valvetrain and skunk2 pro 1 cams
oem overbored head gasket
stock ignition system
Our top mount tial v band turbo kit with a gt3076r .82 a/r hot side
3" downpipe and exhaust
2.5" powdercoated charge piping
600hp garrett intercooler core
tial 44mm wastegate and 50mm blow off valve
gsr transmission
competition stage 5 clutch
quaife differntial
turbo xs dual stage boost controller
skunk2 intake manifold
here are a few original sized pictures too big to put here on the forum:
http://www.synapseturbo.com/gallery/cache/d842156be45dd2d7ebf6b4fd1ee55b737ea3be46_800.jpg
http://www.synapseturbo.com/gallery/cache/0b10c51c122c06ce7e1b111adabd9075229a1663_800.jpg
http://www.synapseturbo.com/gallery/cache/9c70ba39c5b0f6a46620fa3bab42448528fe098c_800.jpg
http://www.synapseturbo.com/gallery/cache/c027eb27f121da3a96bd5667841a1405be6c7fa8_800.jpg
http://www.synapseturbo.com/gallery/cache/4f584c73ea0e1c000edd8e3a62e8f965d7951a3b_800.jpg
http://www.synapseturbo.com/gallery/cache/953ba71397a6832d4b0b8645a94e320cc5f2f9e5_800.jpg
sick!! is it anyone that’s local?
you will definately see it around.
I’ve always wondered, why do the SS lines on everything except the coolant lines to the turbo? It seems as if they would be more useful there than on the valvecover…
That’s Justin’s isn’t it? :nod
the coolant lines used on the turbo were designed for just that they are coolant lines, no need for anything stainless unless for visual purposes. or if they are constantly rubbing against a surface for durability.
the lines on the valve cover arent stainless steel they are actually nylon which is lighter with the same teflon used inside your typical stainless lines.
Its Justins
FINALLY!!!
did you guys powder coat his valve cover there? it looks goo i like it better than the gunmetal it was before…!!! ill be by monday after work to see it and get my ecu…
That thing looks like a beast. I’m lovin the Mugen reservoir cover on the shock tower as well :lol
as always top notch work…
What kind of lines do you run for the return? I saw some blue tubing on the site I am curious as to what it is?
usually when a return line is a blue hose is an Aeroquip hose, commonly used with push-lock, or push-lite AN fittings… and mike… when is it my turn for some work??
blue pushlock hose is rated for 300* and the black is 200* just fwiw. :nod
Thats actually what I was wondering. I might have to switch over. My oil return is leaking. :idiots
cams are ridiculus!!! make so much power down low! and it idles like a worked v8!
What did this car make for power? It was supposed to go on the dyno monday
it made some good power :nod from what mike told me, it was running out of ignition ans started to break up. not my car, i’d rather not say the numbers since its not my car.
Wow that’s clean as hell, great job!
the car made 535whp at 23psi on the stock ignition before it started to break up. with a stronger ignition it still has a bit more room. never the less great numbers and he was happy.
is he running it tonight mike?
