Trying to help my brother sell his car. Check out his posting on craigslist:
http://buffalo.craigslist.org/cto/1923512765.html
Very meticulous about his car, beautiful deep red paint. Family is expanding so the toy has to go.
2000 Pontiac Grand Prix GTP Supercharged and Intercooled. 2 Door Redfire Metallic. Only 63,000 Original Miles. Mobil 1 Oil. Bridgestone Potenza RE750 tires with lots of tread. Rare for GTP cloth interior. HUD Heads up Display, Moon Roof. TONS of new parts. Lots of Modifications. Custom Dash and steering Column Gauge Panel with OBDII Scan Gauge, Wideband O2, Boost, Volts, and Oil Pressure. Runs and drives very very good and Fast!! No Winters since I’ve owned it the past 7 years! Very Clean car, must see! $8500 OBO. Please feel free to ask any questions. Thank You.
MODS
Engine-
-Corsa Stainless Steel Exhaust
-TOG Headers and Down Pipe
-High Flow Cat
-Yella Tera 1.9 Roller Rockers
-Thrasher Cold Air Intake- Modified from 3.5" piping and filter to a 4" setup and insulated.
-Northstar Throttle Body
-Throttle Body Heat Shield
-ZZP Mini AFC 2.0 Air Fuel Controller
-ZZP TAC - Corrects the signal for the larger Northstar Throttle Body
-ZZP EGR Simulator
-ZZP Ported Supercharger- Inlet and Outlet
-Newer Supercharger Coupler and Fluid
-Pulley Boys Pulley System with 3.0 Pulley Installed
-ZZP Ported Lower Intake Manifold
-PRJ Performance Fuel Rails
-Stock Injectors cleaned and flow tested
-ZZP Stage 2 Intercooler
-PRJ Performance Custom Alluminum Intercooler Radiator.
-GM Intercooler Pump w switch ( On/Off/On w Ignition)
-Custom Intercooler Resorvoir
-160 Degree Theermostat
-DHP PCM
-Meziere Electric Water Pump
-Fan Control Switch
-PRJ Performance Spark Plug Wires
-ZZP Poly Upper Motor Mounts
-New Lower Motor Mounts
-Autolite Racing 103 Spark Plugs
-Upgraded Ground Wires
-ZZP Fuel Pump Rewire Kit
-ZZP Alternator Rewire Kit
Suspension/Brakes-
-ZZP Chrome Moly Control Arms
-GM Performance Parts Lowering Springs
-Powerslot Rotors
-Hawk Bake Pads
-GM Performance Tubular Trailing Arms
Interior-
-Custom Dash panel with Gauges
-AEM Wideband Air Fuel Gauge
-Autometer Boost, Oil Pressure, Voltage
-Custom Steering Column Gauge Holder
-Aeroforce Scan Gauge with Pontiac Emblem at Startup
-Custom Dash Cubby Gauge Holder
