My buddy pulled his engine for an LS swap. I’ve driven this car multiple times, runs (ran?) mint. I helped him 5 speed swap this car, not many miles on the clutch.
From CL ad:
Complete pull out IS300 2JZGE Engine and Manual transmission. 150k on engine and roughly 120k on transmission. Engine runs great, trans shifts smooth. I have videos just prior to pulling engine. Video at idle, low rpm and high rpm shifts. Engine has many newer parts incl Timing belt, water pump, front and rear main seals. Some upper front oil seals and gaskets, spark plugs, and some other misc items. Clutch Masters Clutch and Fidanza flywheel have aprox 15k on them. Those 2 items alone were over $600. Also included is ecu, slave cylinder, master cylinder, and harness. Please call or text me with any questions. 716-474-214
