For Sale in West Seneca.
lowered to $4400 cash to nyspeeders
2003 Saturn Ion 1 Sedan
2.2L GM ECOTEC engine
5 speed transmission
Standard model, crank windows, AM/FM stereo, 14 inch steel wheels with OEM hubcaps
AC blows cold, hot heat
94k Miles (about 75 percent highway miles)
I get about 31-32mpg in mixed driving, mostly highway. Best mpg I have seen is around 35mpg all highway.
Plastic body panels means zero rust.
Fold down rear seats.
NO ACCIDENTS ever, no body work, original paint.
All maintenance taken care of. Just passed NYS inspection 1 or 2 months ago…
Car has matching goodyear tires on it with 7/32nd’s of tread, worn evenly.
New Carquest Battery 1 week ago ($99)
New aftermarket alternator 1 month ago ($149)
New air filter/belts/hoses 1 month ago
Regular Oil Changes
Transmission oil was changed with mobil 1 fluid, shifts perfect. Clutch is perfect.
Had a fuel filter a year ago, manual does not require one until 100k, but I like to do it.
Coolant changed every 2 years.
New sway bar links in the front 1 year ago.
I’m the second owner, bought it from a lady on long island who bought it new from a dealership out there.
The only thing I would do to the car was MAYBE put new front pads and rotors on it. They are about 3 years old and the rotors are very slightly warped. Most people would not notice that they are warped, but I’m crazy about upkeep on my cars. It might also need a front end alignment, it is not 100 percent perfect but its not wearing out the tires or anything like that.
Other than that, it needs to be ran through the car wash, and cleaned up a little.
The rear brakes were adjusted and cleaned about a year ago, and everything was bled with fresh fluid.
Its going to be tough to find one as well kept as this car. I have a log of all work done to it, including all oil changes and what oil was used.
Everything is original on this car, no stupid aftermarket stuff, nothing cut up. No window tint, no fuzzy dice.
I’ve had zero problems with this car for the past 6 years, only selling because I’m looking for a SUV for myself because I drive back and forth to Ohio quite a bit.
Thanks,
Justin
