2006 g6 electric power steering motor.
Collision Catalog - 2006 - Pontiac - G6
Steering column, Steering column assembly, Motor assy, Motor assy - With electric steering - With electric steering $278.07 $164.84 $164.84 Delete From Cart
So i found the part i need and the Haynes manual is ordered as well. I also found out you need a tech II to reprogram it after the motor has been replaced and there are no open bullitens / recals for this problem. So now i wonder if it will still drive / steer after the motor is replaced or if it will have to be towed to the dealorship after the part is installed.
any updates brian ?
