Does anyone knows if the 300zx brake calipers will fit inside the S14 16inch stock rims? (The five thick spokes one)
Peter
Peter
Yes, it will fit, without spacers, i guarantee it… Bomex is running it
So is Julian… its confirmed.
With the S14 stock rim it will work, might need spacers if you use the 300ZX rims though. Weird isn’t it.
will it work even it is 30mm?
Yes it will work.
I’m running the 30mm with S14 5 spokes
Will the 300zx brake upgrade work for the stock 15" 7 spoke on the s13’s?
30mm disc as well…
if not, what’s the minimum internal dimension for the rim is required ?
http://forums.son240sx.ca/viewtopic.php?t=2232&highlight=300zx+spacer
5mm spacer?
what about lowering the car and changing the geometry with coilovers…
no chance of hittiing?
Nope the rim is mounted to the hub so there is no chance of things moving there.
The minimum spacer you will need to fit the Z32 Calipers on 7 Spoke
S13 rims is 1/4" or 5mm. You will also need longer wheel studs to
accommodate the spacers. If you don’t want spacers you can always
shave off the Nissan Logo on the front of the Caliper with a grinder.
Sorry to contradict you Phil, but the 26mm calipers will fit under the right style 7 spoke rims without a spacer. This is what I run on my race car.
The right style 7 spoke rims (yes there are two styles at least) have one re-enforcment per spoke, it’s right down the center and follows the contour of the spoke. 30mm calipers do require a minimal spacer though.
-Martin.
-Martin.[/quote]
Martin is right. Asad (superman of amarok.org list) has a webpage with pictures showing which rims will fit which brakes. google it.
Do 1992 300zx 5 bolt rims clear the 300sx brakes on an S14?
This combo is identical to the Z32 setup… Z32 calipers, rotors & wheels. Clearance isn’t an issue.[/quote]
I figured that much but I remember reading somewhere Julian
having a clearance Issue on his S14 with the Z32 wheels.
