Found more stuff:
MINT trunk carpet, no stains. From my 98gtp removed 50k, and in storage for over 7 years- SOLD
Good stock struts, and upper mounts. From my 98 gtp removed 50k, and in storage for last 6 years. I won 50% off, over 1k (total) order @ PFYC.com back in the day. And had to buy something to get a ZEX kit for free. So got KYB struts, and new mounts. Stocks were still great, no winters on the car, all the threads are clean even. Still good for a DD/beater to replace you beat struts. SOLD
Lower trans line. This is nice thats its cut for a trans cooler you can just put the lines on and go. But it also has been fixed with solid line, I ran it for a while no leaks. 4 super mighty tacos
Complete Ac system (firewall foreword). From my 98 gtp removed 50k, and in storage for last 6 years. Worked great, removed to save weight. $150 for everything
97-98 stock, airbox complete (get a new filter) good for the winter over you FWI/CAI $20
clean, low miles, res nip is broke, just change with yours. $20
4t65 HS diff cover, with VSS sensor very clean $20
very clean L67 ballencer $25
1/4 universal wheel spacers $10
ford think there 5x8 speakers. form a focas, Only needed one for my van these 3 are fine.
gauges autometer sportcomps. ele oil presser, mac boost/VAG, ele trans temp. with senders, and harness to wire for Apiller style. SOLD
LS6 cam valve springs SOLD
NEW in box felpro L67 vavlve cover gaskets, and bolt seals SOLD
ADDED>--------------
97+ Wbody steel cradle, mint shape. No WINTERS, never had salt on it. Car was never off the road, no dents from hitting anything, towing damage, things like that.
FREE !!!
must pick up in churchville. PM me for more info
Nope gone years ago.
