selling for a friend, feel free to as any questions…
all these parts sitting around taking up space in his garage, he will NEVER use these again,so the first reasonable offer will be accepted. Shipping is included in price unless specified.
factory mazda r1 spoiler, in good condition. ($250)
Factory mazda subframe in perfect condition ($150 plus shipping)
Factory engine harness (turbo control solenoid plug has been modified) ($250 shipped)
Secondary fuel rail ($35 shipped)
Aftermarket air separator tank ($45 shipped)
pettit racing air intake system ($150 shipped)
power steering pump ($100 shipped)
clutch master cylinder ($30 shipped)
oil cooler W/ 10 a/n fittings on it ($150 shipped)
factory tie rods (15k miles) ($40 shipped)
factory power steering pulley 1yr old ($35 shipped)
power plant frame, welded and reinforced ($200 plus shipping)
factory drive shaft, good U joints ($100 plus shipping)
oil Supply lines ($20 shipped)
ABS Control unit ($20 shipped)
Aftermarket pulleys ($50 shipped)
BNIB Racing beat rear sway bar NEVER USED w/bushings ($140 shipped)
Clutch slave cylinder ($25 shipped)
Fuel filter as pictured 3k miles ($25 shipped)
Cruise control control unit ($30 shipped)
Coolant filler neck assembly ($25 shipped)
high flow cat (gutted) ($110 shipped)
Oil return lines ($25 shipped)
2nd gen ignitor coil ($50 shipped)
3rd gen ignition coils, leading & trailing ($75 shipped)
3rg gen ignitor box ($15 shipped)
Factory BOSE rear carpet )$60 shipped)
factory tortion LSD still perfect ($100 shipped)
ACT light flywheel (12lbs) w/ counterweight ($150 shipped)
ACT pressure plate ($200 shipped) Comes with disc but disc is pretty spent
lower Intake manifold ($75 shipped)
jacobs Rotary propack BNIB never used ($200 shipped)
Coil pack harness, brand new ($25 shipped)
Throttle body w/ gasket and all sensors ($75 shipped)
3 bar GM map sensor ($40 shipped)
Rotary performance downpipe w/multiple o2 bungs ($125 shipped)
Stock Twin turbos (6/10 condition, turbine wheels slightly nicked, don’t burn oil) ($250 shipped)
