So I had a great idea a few years ago. I was going to build a walk in cooler in a great house that I was buying. Well, I lost that house and ended up in a house with a much smaller basement; My family has grown to FIVE; and now I finally have a large home with a lot of useless SqFt that I want to make awesome. (for the record I still put a small cooler in that house with 3 kegs, just not something this cool)
We have been working non stop on this house and I really wanted to document our flip on here as it is really awesome what you can transform when you put your mind to it. I failed. I have been so busy trying to balance work, family, projects, relaxation etc… that I just didn’t do it. That said I have this really cool walk in project that I have been DYING to build for years. Here is the original thread where I was so on top of it and just ran into a wall. http://www.nyspeed.com/showthread.php?81264-DIY-Walk-in-Cooler-(not-really-auto-related-)/page3&highlight=cooler
Well that ends today.
I have allocated the space and created the drawings. The foam board, subfloor materials, and 2x4’s are on site and this week I will have the AC, coolbot, insulation etc… to get this going.
On with the details.
So my basement in this house has 82" ceilings. Not the best but good enough that I can finish it and add on a 675 sqft rec room with a bar, cooler, and bathroom. There is already a large office and a nice workshop completed. There are only three windows to the outside so the placement and size of the cooler are limited by those.
Here is the current ROUGH design:
The cooler is much more scaled down from my original design and over five years and several project houses I have learned a TON about construction and proper building. I will be constructing the cooler “First” and following as I ahve time on the rest of the bar, living space and bathroom. The bathroom has to be framed and the cooler facing wall drywalled but that is the extent of the bathroom for a couple months.
The process for this build will be:
Sub Floor. I will be using 1.5" XPS foam on the floor pushed to within 1/2" of the same foam on the outside walls. I will fill that seam with some expanding foam that will still maintain some flexibility so that there is no chance of my floor buckling with temperature change. All seams on the foam will be taped with Tyvek tape. On top of this foam will go plywood or ZIP OSB. I already own a decent amount of the plywood but at something like $36 per board I may go the coated ZIP osb route as it is (a) coated and (b) around $20 per board. I am also considering returning all of this and ordering http://www.homedepot.com/p/Amdry-2-09-in-x-2-ft-x-4-ft-OSB-Insulated-R7-Subfloor-Panel-AMD0150G/204395337 Not sure I want to use this system or wait for delivery… I will be debating this for the next day or so.
Walls. The walls will be built using 2x4’s. I really should be using 2x6’s, but this cooler is very small and I can insulate it properly using 2x4’s so why the hell not. The 2x4 walls will be built on top of the insulated sub floor and will be sealed with foam. The walls themselves will be filled with Roxul (mold and water resistant) and an R-value of 12. They will then be covered with 2" of XPS foam, R-value of 10, which will again be sealed to the subfloor with Tyvek tape. this gives me an overall R-value of 22. the industry standard is 25 but this is a tiny ass cooler and it will be 100% air tight as I will foam and tape everything.
Ceiling. This will have the same roxul foam combination as the walls.
Finish work on walls and ceiling. This will be done quite simply using stainless screws and FRP which is the same plastic sheathing that is used on commercial coolers. I will silicone all seams and corners for another air tight layer.
Finish work on floor. I will be using a cheap ass laminate. The reasoning behind this is that the Home depot traffic master flooring is super easy to use, looks awesome, .99/sqft, and best of all it is all rubber and plastic making it incredibly moisture resistant.
That is all for tonight. I am going to start building tomorrow night and I should have a couple pictures up by Thursday hopefully. I know that I have a couple of electrical lines to get over there and prepped for the cooler, and a couple copper pipes to reroute so assuming that only takes a few hours this should be framed in no time.
Oh, and instead of building my own awesome controller for the cooler someone took the initiative to make a consumer product that accomplishes the same task with way less work and thought.
