Bought a couple of new TV’s and decided this was not worth the space anymore. The picture quality is great, but I can’t keep such a giant stand with little children running around.
First the Stand:
I can not find this one online anywhere but it is quite large. the top surface measures 58"x19-3/4" and it is 26-1/2" tall. There are some minor scratches (one repair area), but nothing to big and glaring. This is about 4 years old so it has some wear. In the pictures you can see through the back, this is not the case when in use as there are sliding doors on the back that shutter it.
I paid something like $4-500 for this thing, would like to see $100
The TV.
It is a Samsung DLP and NEEDS A NEW BULB.
I had lifetime service come out and change the color wheel as the original had failed (google white dot syndrome, it was a common issue) when he did that service he told me the bulb had nearly double the rated hours on it. I decided not to pay him to change it, and a couple months later it died. I an not going to change the bulb as I do not want the TV any more.
Looking to get $125 for the TV.
Here are the pictures, the specs follow.
Make a big impression in a limited space with Samsung’s high performance, value-packed, energy-efficient HL-T5075S. The thin bezel and hidden speaker system let you enjoy more screen and less frame. With a slim 13.4" depth and remarkably light weight, it’s the set that fits where others won’t™. This 50" DLP® HDTV offers the crisp definition and bright imagery of Samsung’s Cinema Smooth™ 720p light engine; a 2500:1 contrast ratio delivers vivid colors, bright whites and deep blacks, all in fine detail. SRS TruSurround XT™ audio fills the room with clear, robust sound. Game Mode optimizes performance so gamers will marvel at the lifelike action. Enjoy the versatility of a wide range of A/V inputs, and 2 HDMI ports that allow digital connectivity to Cable/Satellite boxes Blu-ray players, AV receivers, and more.
<b>Features</b>
 <b>3D HD ready.</b> The HLT generation of Samsung DLP® HDTVs are capable of displaying future 3D games, movies, and other programming via 3D compatible glasses and hardware.  <b>SRS TruSurround XT™.</b> TruSurround is a patented SRS technology that solves the problem of playing 5.1 multichannel content over two speakers. TruSurround delivers a compelling, virtual surround sound experience through any twospeaker playback system, including internal television speakers and headphones. It is fully compatible with all multichannel formats up to 6.1 channels.  <b>Brilliant Color™ II</b> provides brightness increase in non-primary colors and boosts overall color intensity.  <b>V-Chip</b> enables parental control for channel and program blocking of TV programs that incorporate the rating code signal. <b>Tech Specs</b>
 <b>Display Performance</b>  Video display rate: 120 Hz  Response time: 16 micro seconds  <b>Video</b>  Display device: Single digital micro  mirror device  Pixel count: 1280 horizontal x 720 vertical  Color wheel: 55 mm/5 segment  Resolution: 720p  Contrast ratio: 2500:1  Channel coverage: VHF 2-13,  UHF 14-69, CATV 1-125 (up to 181  pre-selected channels), ATSC 1-69  <b>Video</b>  Output power: 10Wx2  Speakers: 2  Sound effect system: TruSurround XT™  MTS stereo  <b>Power</b>  Voltage, Line frequency: 100-120V 60Hz  Power consumption: 200 Watts  Standby power consumption: 0.8 Watt  <b>Connections</b>  S-Video input: 2  Component video input (Y/Pb/Pr): 2  PC (RGB) input: 1  RF inputs: 2  HDMI: 2  <b>Quality</b>  Warranty: 1 year parts and labor  warranty, including lamp, with in-home  service backed by Samsung toll-free  support. 1-800-SAMSUNG  Energy Star® Compliant reduces  energy consumption by up to 25%  compared with standard TVs.2  Accessories  Universal Remote Control  <b>Net dimensions</b>  TV (w/o foot): 45.2" x 31.8" x 12.8"  56.7 lbs.  TV (w/ foot): 45.2" x 31.8" x 13.4"  Order code: HLT5075SX/XAA  UPC: 036725250758
Product Attributes
Aspect Ratio: 16:9
Display Technology: Projection
Response Time (ms): 16
Speaker Output Power (W): 10
Tuner: ATSC
TV Features: Closed Caption / Flashback
TV Refresh Rate (Hz): 60
TV Screen Size (inches): 50
WILLING TO TAKE $175 FOR BOTH
[SIZE=4]D[SIZE=4]eli[SIZE=4]very may be an option but I no longer have a truck, just an SUV so I may no[SIZE=4]t be able to fit it.[/SIZE][/SIZE][/SIZE][/SIZE]
